Help me please!
Old Oct 23, 2005 | 04:05 PM
th3br4d's Avatar
Exclamation Help me please!
Alright, I got my RSM installed and the car was running fine. I went inside to change and came back outside and sat in my car, turned the key and all I got was a clicking noise. The battery is fully charged and we also tried another battery and it still did it. Well, come to find out the starter was bad. I buy another starter and now my car is really not working. I open the door and the dome light is on but very weak. If I let it sit for like 10-20 minutes then open the door the dome light is bright but and the accesory function works but once I move the key one more forward all the power goes out. We took the main power wire off the starter and it still does the same thing. Anyone know what it could be?
Old Oct 23, 2005 | 04:35 PM
BigVinnie's Avatar
You are having a grounding issue, check all gound wires...... Or matbe even wires that shouldn't be grounded...
Old Oct 23, 2005 | 06:54 PM
jbask's Avatar
Bad ground for sure, I had the same problem with my 240. I pulled out the starter thinking it was bad and bought a new 1. Then found out that it was a bad ground when the new starter did the same thing. You should bench test your old starter to see if it is still good. Then put it back in and return the new 1 you bought. The ground wire that went bad on my car was the main ground off the batt (I relocated the batt to the trunk when I installed the sr).
Josh.B
Old Oct 25, 2005 | 06:38 AM
super short. check everything you touched before installing the RSM
USMCDrifter
Aug 22, 2009 10:20 AM
japporeyser
Apr 7, 2004 08:15 PM
90two4tsx
Oct 20, 2003 01:16 PM
240SEX
Jun 1, 2002 09:35 PM
leiferik1
May 6, 2002 01:04 PM
