Help!...quick!
Old Mar 8, 2006 | 07:40 AM
anonymous_240's Avatar
Help!...quick!
hey guys well i have a problem with my car...some how my gauge lights and all of the lights like the defroster etc. arent working...so im wondering if its the fuse or some wiring problems.
also when i turn on the defroster my exhaust makes a louder sound. so im wondering wut that is all about too.
Old Mar 8, 2006 | 09:15 AM
Did you check your fuses? If not, do so it may be the problem. Did you mess with the cars wiring before this happened at all?
Old Mar 8, 2006 | 09:20 AM
Initial Daniel's Avatar
First I'd definitely check the fuse, then check the wiring between the gauge cluster and where they run into the ECU or their place in the engine bay. Use a meter to see if you're getting 12 volt on the suspected wire. If the wiring is good, then check the harness. If the harness is good, then check the actual unit itself (the gauge cluster and other lights).
Check your dimmer switch too. Hopefully it's just a fuse. Electrical problems are a pain in the ***.
Old Mar 8, 2006 | 10:43 AM
barcode's Avatar
yeah check the dimmer switch, my freinds went out and every single dash light just stop workin. I dont think that would have anything to do with ur exaust tho.
Old Mar 8, 2006 | 06:53 PM
well the exhaust sound just becomes louder when i turn the front defroster on with the heater on. and the fuses are all good. i think its the wiring. no i didnt mess with it. i just bought it and im still trying to contact the original owner. i just had my uncle check it since hes a auto mech. and he says maybe its the dimmer switch that got fried or the wiring around the stereo. which i think its is that. also my speakers arent working either so im thinking it really is the wiring. thanks for all that up there.
Old Mar 8, 2006 | 09:18 PM
dued's Avatar
Thumbs up
I would like to suggest checking the alternator also, since it might be very easy to test. Have your uncle perform an alternator check by unplugging the battery while the car is running. I'm not quite sure how this works, maybe he does, as I haven't ever done this before.
Old Mar 9, 2006 | 07:13 AM
alright i'll try that, though he says my car is a pain in the *** lols...
needa240
Jan 1, 2005 11:16 PM
needa240
Dec 21, 2004 06:59 AM
etchebarren72
May 3, 2004 04:40 PM
Misfitflesh
Oct 11, 2003 08:14 PM
SilvaPwr
Nov 22, 2002 11:26 AM
