how do i get this replace?
Old May 18, 2005 | 12:31 PM
ninedy_to_koop's Avatar
how do i replace this power steering hose/line whatever it is? It's crack and i have to go through a quart of p/s fluid every 2 week and 1 quart every 30min drift session. i'm a dumbass....help. i have finals so please. i looked at it and it look like an headach to get it replace. i thought about putting ducktape on it but... it'll never work so i never bother. I'm a cheapass ****.
Old May 18, 2005 | 02:04 PM
GreenPunkBlood's Avatar
it looks like you already have it out, so all ya need to do is buy a new one and install it the same way you removed it.
Old May 18, 2005 | 05:07 PM
its not mine... i took the picture from ebay. Mine is still on my car.
Old May 18, 2005 | 08:42 PM
I'm with Stupid's Avatar
Is it actually cracked or just leaking? And by ps fluid do you mean that power steering fluid you buy at the store or atf?
Old May 18, 2005 | 10:31 PM
p/s steering my man... i don't see a crack so it must be a leak... it leaks alot where its connected to the pump. any suggestion my 240 homies...
Old May 18, 2005 | 11:36 PM
Power steering fluid will ruin you system and will cause leaks. Our cars take atf, switch to atf and it may stop the leaking if your system isn't too far gone.
Old May 19, 2005 | 07:02 AM
Sevarg710X's Avatar
Mine was leaking and it turned out the bolt where the line connects to the p/s pump was loose . So I ightened and ta-da fixed .
Old May 19, 2005 | 08:45 AM
I dont mean to hijack but, what type of ATF should be used. I have some MOPAR 7176 (ATF+3) and im going to be replacing my SOHC P/S with a DOHC when i do my swap. Is it ok to use this stuff?
Old May 21, 2005 | 03:14 PM
Slidin240's Avatar
not to sound like a noob but... ATF?? (im guessing Automatic Transimission Fluid?)
Old May 21, 2005 | 03:42 PM
AAV240sx's Avatar
yes, atf is automatic transmission fluid
240sxFan
Apr 25, 2004 07:06 PM
U_NeeKz
Apr 6, 2004 01:25 PM
95_240SXSE
Feb 17, 2004 08:48 PM
l2aine
Dec 27, 2003 04:55 PM
SlydeSHO
Sep 3, 2003 11:17 PM
