Intake??
Actually, it should. the only thing is you might have to make a custom mounting bracket for it. I have an AEM short ram on mine, and the mounting tab didn't line up, so I used a zip tie to hold it in place, and it works good. I don't know about the cold air extension tho.....
From: San Antonio, TX USA (Actually from Tampa, FL/Stuck here in TX due to military!)
The Injen extension for an S14 will work. You will have to cut the extension down a bit and maybe shave a bit off the MAF adapter. I installed a no-name short ram intake with the Injen extension on my S13 hatch and it fit fine after a little adjustment.
aznchico69
May 10, 2005 02:17 PM
PissonH
Nov 25, 2004 07:38 AM
