Intake system
I believe he is talking about the AIV box that is on s13's. You can put a breather where the tube comes out of the box, or you can find a MAF adapter that will work with it, or you can remove the AIV all together.
The box right next to the ignition coil right?
hey s13 240 yea that is the tube im talking bout, that tube coming out of the aiv box u talking bout... wat did u do with it ne pic i could see where u connected it to or can u explain clearly bout putting a breather where the tube....lmk thankz
My filter is the K&N filtercharger kit or something like that and it has a spot for the hose to connect, I did have to get a longer hose (Lowes) for it to fit correctly though.
When I say put a breather on it, you will need to go to Pep boys or whatever is in your area, and it will look like a mini cone filter, get the right size and you should be good to go. I may be able to get a pic off of my friends car to explain it better.
nissans13
Aug 23, 2006 02:54 PM
aznchico69
May 10, 2005 02:17 PM
PissonH
Nov 25, 2004 07:38 AM
wishicoulddrift
Sep 1, 2004 10:49 PM
