intake tech
intake tech
http://www.hondalife.com/articles/intaketech.htm
i know it's honda, but its good info
i myself am going to relocate the battery to the trunk and build a custom cai that runs from the TB to inside the front bumper on the passager side.
I have plans to relocate my battery to my trunk as well. I want to make as much room as I can in the engine bay for pipes and all. I was looking at a car with a CA in it and the antifreeze bladder was just laying in the compartment. Space becomes tight when you have pipes running all over the place.
yo, this is kinda dumb but how do people go about adding an additional battery ... lets say u want to hook up a really powerfull system, and u leave a battery in the regualr spot, how do u go about adding a battery to the trunk ?
not 100% on this cuz i really hate electrical ****, but don't you just hook up the negative to any sheetmetal piece that connects to the frame and then run your positive to whatever you want to power?
I would think that you would run a leg off of your current battery so that the system battery would be charged by the altinator as well. You might just have to wire it in series with the main battery.
I would take it that you would need a higher output altinator while you were at it.
Why don't you just wire in some capacitors? They will store a charge and release the extra amps needed when the system kicks in.
Your stock alternator would never be able to power two bateries, even an aftermarket alternator would not be able to keep them fully charged thus reducing life in both batteries. The only way to do it is independantly, but you have to change the battery each time it drains (or get a battery charger for your garage). If you are feeling really special you could try hooking up another alternator through your belts system, maybe get rid of A/C to compensate hehe, it would be tough but I have seen it done once. I would recommend just getting a good aftermarket alternator, battery, and a couple of caps.
http://www.club240.com/forums/showth...6136#post16136
refer to this thread for more, I guess I might be wrong about the setup. I'm still not sure how well the second battery setup would hold up, if anyone has tried it post in the thread above, i would love to hear about it.
aznchico69
May 10, 2005 02:17 PM
PissonH
Nov 25, 2004 07:38 AM
Zdrifter
Feb 27, 2004 06:59 PM
