A lil help, 240sx smokes alot...
Ever since I got the car (2months ago) it has been smoking when starting off in first, and changing gears.It also smokes alootttt when rev it up around 3000 RPM or more. (White smoke) Anybody have an idea? I feel embarass when someone is behind me at a redlight. :-/
rings, valve stem seals,ect. Might be time for a rebuild. Check you comp while your at it. If its pretty low(under 150) put little drops on oil into the cylinder and recheck comp. If its raised then your rings are ****ed. haha.
Mabey your burning coolant instead. So theres lot of things to check. like a worn intake mani gasket, **** like that.
kandy supra
Apr 18, 2004 04:45 PM
