TCSportline ground kit is GARBAGE!
Old Nov 11, 2007 | 08:35 PM
bucket240's Avatar
I have been having problems with TCSportline ground kit since I have owned it. I end up stuck somewhere cause the damn thing won't make the proper connection. I even had to sand down the coat of paint which is gold and I guess it was sappose to look like real gold but its crappy *** paint that doesn't even conduct electricity. Even with it sanded down it only lasted about a couple of startups before it stops working. Don't buy this garbage.
here is the link if you don't know what I am talking about.
http://cgi.ebay.com/ebaymotors/NISSA...spagenameZWDVW
Old Nov 11, 2007 | 08:56 PM
I dont understand..... they're wires, how can they not work? I understand the paint issue, but after you sanded it down.
Old Nov 12, 2007 | 06:33 AM
bucket240's Avatar
I guess it has something to do with the main distributor plate, going to run all the wires to just a regular battery terminal.
Old Nov 12, 2007 | 09:30 AM
TCSportsline is dump from all the reviews I hear
Old Nov 12, 2007 | 01:13 PM
bucket240's Avatar
I just took it off and inspected it, it was corroded and it has only been on there for 2 days. The plate is made out of aluminum, is that the standard material for ground wire kits??? I think that might be the problem (cheap aluminum).
Old Nov 12, 2007 | 05:01 PM
just get ride of the plate thing and hook the wires up to the - terminal. i have some ebay ground wires and they work so well that - terminal doesn't have to be on the battery for the car to start.
now that's some good grounding.
Old Nov 13, 2007 | 12:18 PM
positron's Avatar
I got one of those things, I'm taking it off when I do my swap.
Old Nov 13, 2007 | 07:57 PM
BigVinnie's Avatar
The problem with that TC sportline it that it doesn't have a direct chassis ground.
From the battery to the engine there needs to be a splice in between to the actual chassis. If not it can cause the battery to surge and can actually cause to blow fuses, and relays.
Old Nov 13, 2007 | 09:20 PM
bucket240's Avatar
Actually you can put the wires anywhere you want, I got two going to the chassis from my battery.
Old Nov 13, 2007 | 09:39 PM
BigVinnie's Avatar
No you need to have an inline grounding source.
Which means a wire that runs from the negative terminal of the battery to the engine. In between the engine and battery wire there is a splice in the line and grounded to the chassis as well, this prevents any type of grounding disruption, this is a splice usually 12" from the battery, and 12" from the engine.
The engine itself conducts a massive current as spark plugs alone ground out to make a spark. Then there is kinetic energy and other types of current that takes place. You need a splice between the engine and battery to chassis, the battery terminal alone doesn't cut it.
Not to mention that gauge wire looks much o thin in the ebay pics, I wouldn't buy it just looking at the pic.
RB26DETT_240sx
Oct 11, 2005 05:38 PM
deloesian
Dec 28, 2004 10:24 PM
jackyliem
16
Dec 9, 2004 10:40 AM
bgbowlerfreak
Jun 21, 2003 09:25 PM
DeFcOnS14
Feb 23, 2002 12:26 PM
