Loosing power steering while drifting?
Old Mar 28, 2005 | 12:38 AM
redline808's Avatar
Has anyone had this problem? We had an event today and I noticed while drifting through our tight section of the course my steering wheel became hard to turn? After I opened the hood, I noticed fluid was coming out of the reservoir, I opened it and it was still ok on the level. Does anyone know what is happing and a solution to the problem?
Thanks
http://www.redline808.com
Old Mar 28, 2005 | 12:54 AM
check and see if ur boots are still on ur tie rods, if not, the liquid can leak from there all over the bottom of ur motor and car,
u could also have a slow leak in one of ur hard lines, which is made fast when under pressure.
also verify that that liquid is ps fluid
Old Mar 28, 2005 | 01:04 PM
98cwitr's Avatar
pump might need replacing
Old Mar 28, 2005 | 01:57 PM
BigVinnie's Avatar
Lucas oil makes a power steering fluid that will revitalize seals, and increase the pressure in your power steering. I recomend it because I am using it and have the same problem. It will prevent air, and leaking from occurring.
modest180sx
Dec 24, 2006 09:58 PM
NismoS13Drifter
Jul 5, 2006 09:06 AM
seal3k
Aug 8, 2005 01:17 PM
ProjectMy240
May 12, 2005 07:42 AM
240sxFan
Feb 27, 2004 07:29 PM
