max psi on bottomend?
Old Nov 11, 2006 | 11:13 PM
SRWHAT's Avatar
Question max psi on bottomend?
What psi can you safely run, and occasionally play with on a stock SR with basic bolt ons (e/i)...I am installnig a BC and am wondering what would be a safe setting boost wise for playin? something to be safe and conservative, but not too granny?
Old Nov 12, 2006 | 06:31 AM
jspaeth's Avatar
Boost doesn't really have that much meaning.....what really matters is total airflow.....
For example, on a T25, the turbo is inefficient after ~14 psi or so...and will probably fail eventually. However, with a larger turbo, you get the same airflow to the engine (and thus horsepower output) with less boost.
For the T25, I would say keep it below 14-15 psi if you want it to last.
Also, bottom end is typically good for up to ~400 hp or so....
Someone please correct me if I am wrong
Old Nov 12, 2006 | 10:30 AM
yeah im pretty sure the stock SR T25 turbo isn't meant for cranking too much boost and will definitly wear itself out after 13-15psi
Boosted240
Feb 25, 2005 02:24 PM
altima-125
Oct 14, 2004 02:06 PM
240sxFan
Sep 15, 2004 07:29 PM
asalatt
Dec 30, 2003 08:03 PM
Silas
Nov 15, 2003 01:06 PM
