messed up wheel alignment
Old Aug 29, 2005 | 09:50 PM
flying_chicken's Avatar
my front camber and caster r off.. I was told that they arent adjustable..
how can I correct them?
as for my rear... the driver side got toe in.. cant really toe back out..
the adjustment nut works... for toe in.. but seems not really work so well to toe it back out.. is it a common problem? anyway to correct them?
Thanks
Old Aug 30, 2005 | 04:01 PM
question #1: did you lower the car, change any suspension components, or crash into anything?
Answer that, then I can probably help you.
Old Aug 30, 2005 | 09:44 PM
none of the above, but the car has not been driven for a while
Old Aug 31, 2005 | 03:03 AM
wikd240's Avatar
update the suspention with adjustable parts and go from there... that will give you the caster and camber adjustments you need as well as toe adjustments for the rear... helps with saving tires too... i am in the same boat... need to buy all kinds of suspention parts to get my alignment back up to snuff after lowering the car... im putting the stock springs back in it until i can get all of the suspention parts im going to need to get it driving straight again...
scooter344
Jun 8, 2008 04:53 PM
wantadvice
Nov 11, 2005 03:46 PM
S13freak
West Coast/Hawaii
Nov 18, 2004 12:30 AM
needasr20
Jun 28, 2004 04:18 AM
sanghl
Northeast
May 31, 2003 08:08 AM
