my car isnt starting...
Old Nov 28, 2006 | 08:39 PM
anonymous_240's Avatar
ok guys well at first my car will start but dies randomly because the idle was too low. (i need professional help) anywho my friends were telling me the same thing happend to them and they changed their fuel pumps. so today i did that and now my car isnt starting. its like there isnt any fuel to start the combustion.
Old Nov 29, 2006 | 12:23 AM
you sure its working try taking out the feul pump and connenct a wire from the battery power and ground to the fuel pump to see if its working. if it is working try checking your battery if its low on power then its probably your alternator. if your alternator is bad then your car wont stay on because the battery is only used to start the car and dampen electrical spikes and the car runs off the alternator, but if the alternator is bad the car will run off the battery completely and it wont stay on for long and it will bog and shut off. so check to see if your pump is working then check battery voltage (should be 12-14v) if lower then normal voltage then its probably your alternator. goodluck!
nismoman
Jul 31, 2006 04:54 PM
skifux21
Feb 23, 2006 08:40 PM
bcmcbee
May 25, 2003 10:26 AM
rbboyl
Jan 20, 2003 03:11 PM
Bigunitsnake
Sep 23, 2002 02:23 PM
