Nasty noise from steering..
Old Jan 28, 2006 | 01:45 PM
Skyline0586's Avatar
Recently bought a used 240 95. When i turn the wheel it makes a loud noise as if its struggling. Could it be the power steering pump? rack n pinion? etc...? its the loudest when im standing still, but it does make noise when im driving also.
Old Jan 28, 2006 | 04:49 PM
BigVinnie's Avatar
More than likely power steering pump is going bad. Or the seals on your rack and pinion are screwed. Check the rack first for leaks. If no leaks, then replace the pump.....
Old Jan 28, 2006 | 06:00 PM
kno of a good site that sells OEM stuff at a good price?
Old Jan 28, 2006 | 10:04 PM
iNmotioN's Avatar
hey it might just be that youre out of powersteering fluid.
Old Jan 29, 2006 | 01:37 PM
nope already checked that good suggestion tho. i wish it was that simple haah
Old Jan 29, 2006 | 09:29 PM
Zephyr's Avatar
check your lines as well.
Old Jan 29, 2006 | 11:31 PM
DGibb's Avatar
How did you "check" the fluid? The fluid can be all the way to the top of the container and STILL be low. Get some power steering fluid for a couple of bucks and try pouring some in, you might suprise yourself to see it gurgle it down.
Old Jan 30, 2006 | 11:24 AM
thanks, yea thats exactly what i did. i filled it up to the max and it didnt fix it. prob a bad pump
Bryan
Jan 24, 2006 11:54 AM
JDMxDrift
Mar 5, 2005 01:50 PM
konseiEva
Jan 28, 2003 10:27 AM
drifties151
Oct 8, 2002 12:30 PM
RNN14
Feb 19, 2002 10:33 PM
