need help. i could die
Old Feb 28, 2007 | 02:41 PM
davvvid's Avatar
Thumbs down need help. i could die
my windshield whiper like stopped working suddenly. i still here the motor runnin when i put them on but nothing happens. i have no idea where to start, anybody have any ideas or things i should check out
Old Feb 28, 2007 | 04:03 PM
bob804796's Avatar
check the splines in the wiper system were the arms connect. thats what went wrong on my ford. still thats domestic. im sure imports are different but its a start
Old Feb 28, 2007 | 05:57 PM
re037's Avatar
pull off the plastic cover in front of the windshield and have a look
Old Feb 28, 2007 | 06:39 PM
LA_phantom_240's Avatar
Yeah. Check the splines on the shaft to make sure theyre A) not stripped and B) the motor is turning the splines.
Old Feb 28, 2007 | 07:27 PM
davvvid's Avatar
the splines are under the plastic vent thing? does it just pop out?
Old Feb 28, 2007 | 07:32 PM
yeah the whole windshield wiper/front plastic drain is real easy to take apart, like 5min. There are about 5 screws
Examine everything and make sure nothing is snapped or loose.
Old Feb 28, 2007 | 08:01 PM
Repaint if neccessary while youre at it.
Old Feb 28, 2007 | 09:30 PM
if the wiper blade aren't moving then the spindles are probably striped and they should just pop out.
better yet grab the wiper blade and try to move it. if it moves with little or no resistance then check the nut that hold the blade in place and tighten it if need be
JDMLyfeStyle
Dec 19, 2005 06:08 PM
TougeNinja
Oct 9, 2005 11:26 PM
{nBw}Showtime
Jun 1, 2005 09:21 PM
leiferik1
Apr 11, 2003 11:33 AM
