new guy (sr20det swap) need help
Old Sep 5, 2003 | 01:11 AM
viperguy's Avatar
Hello everybody, I have a few questions that I like to ask you expert here. I want a 91 240sx hatch and I want to do a engine swap on it. The engine I have in mind is the sr20det. If anybody know any better engine for this swap plese tell me and explain why. Anyway my question is what do I need for this swap? Is the engine mount the same? When I do get this swap, my main concern is if this motor ever fail, which it will, can I buy part in the US to fix it or do I need parts from Japan? I'm not talking about blowing a piston or head but thing like a bad starter, alternater, fan belt and such. Is there another engine in the US that carry the same part for this car? Now if I do blow a head or piston than I definitly need parts from Japan right!
Old Sep 5, 2003 | 07:19 AM
runyun's Avatar
try the "search" button
Old Sep 5, 2003 | 10:05 AM
I got this off of another forum, I'm just passing it along:
Exhaust Manifold Gasket '91 Sentra SE-R w/SR20DE
T25 Turbo gaskets '90-'95 300ZX TT T25 gaskets (note turbo to O2 housing gasket dose not fit on S13 T25)
O2 sensor '87 300ZX Turbo
Ignitor chip '95 Q45
Fuel Injectors '95 300ZX TT (purple plugs)
Fuel Injector Seals '95 300ZXTT kit
MAF '89-'90 SOHC 240SX
Tranny rear main seal '93 240sx
Slave cylinder '93 240sx
T.O. bearing '93 240sx
Pilot bearing '93 240sx
Clutch 89 Nissan Maxima 240mm 9-7/16" spline 24x1
Belts (PS, AC, alt) Gates K050370 Alt. K040345 PS & AC
Spark Plugs NGK BKR7ES11 or BKR6 (hoter plug)
Coil Packs '90-'95 300ZX or '95 newer Maxima
S14 SR Oil Filter '95 Sentra SE-R
S13 SR Oil Filter '91 Sentra SE-R
Fuel filter '90 300zx TT
Front and Rear main seal '91 SE-R
TPS '95 KA TPS will work with some soldering
Temp sensor S13 or S14 (depending on chassis not motor) KA24DE temp sensor
Thermostat '91 Sentra SE-R
Radiator cap '90 300zx TT (slightly more pressure for better cooling over stock cap)
Knock sensor '95 240sx
Oil pressure sender '95 240sx
The only parts you really need to get from Japan are the starter, alternator, water pump, and headgasket.
Old Sep 5, 2003 | 12:24 PM
viperguy's Avatar
Thanks guys!!!
fukkeneh240
Jan 13, 2006 08:07 AM
nismodragon19x
Dec 24, 2005 12:16 AM
TC23
Sep 9, 2004 04:44 PM
nissandrift
Feb 21, 2004 11:18 PM
viperguy
Oct 8, 2003 01:59 PM
