Newb 240 HELP!
Old Oct 1, 2005 | 04:45 PM
jason861's Avatar
Newb 240 HELP!
I just picked up a 240SX...
1989 w/ 2400 12 valve
Basically its got no *****... It was running fine for the drive home but once I started looking at it the plugs on the throttle body were disconnected
I plugged them back in and now have no power at all. It starts fine, idles fine, rev's fine. But when in gear it is gutless. I disconnected the plugs like the way it was and still nothing? I disconnected the battery to reset the ecu with the TB plugs on and off and still nothing Everything worked fine minutes before re-plugging in the TB plugs, even when not plugged in, it wont go back to the way it was
What could be wrong?
Thanks for helping the newb out
Old Oct 2, 2005 | 02:09 PM
jason861's Avatar
anybody have any ideas?
Old Oct 2, 2005 | 02:20 PM
nsn240's Avatar
if its on the throttle body... there are vacuum lines... post some pictures. I thknk you probably have them plugged into the wrong places
Old Oct 2, 2005 | 02:57 PM
jason861's Avatar
well there was one vacuum that got unplugged but I thought I found where it went. There are no vacuums going to the throttle body atleast from the top.
The one vacuum that was unplugged came from the cylinder/box on the driver side under the brake master cylinder. The vacuum that comes straight out of the bottom is the one that was unplugged and I didnt really find where it went.
Where/ how many vacuums should be on the throttle body?
Thanks a ton!!!
Jason
customerservice
Jan 31, 2007 10:38 PM
240sedrifter
Sep 15, 2005 08:39 PM
tweak302
Jul 30, 2004 04:23 PM
SupraJames
Apr 16, 2004 01:33 PM
markins06
Jul 8, 2003 10:33 PM
