newbie with questions
Old Aug 9, 2007 | 07:24 AM
ridin4jesus's Avatar
just want to say whats up to everyone, i was apart of clubcivic but now im where i belong =D. had a few questions though, i just picked up a 91 240sx se and im having some problems. the fan blower wont blow on 4, and the a/c works every now and then. the cruise control and the seat belt motor have worked once since ive had the car. the seat belt chime sometimes goes on a rage and chingles like its crazy. and last but not least the car sometime loses rpm's when i take off from a red light, it goes down but then back up and goes. I checked the fuses under the driverside and the fuse links and the only thing i see is that there is a 15a fuse where a 10a fuse should be for the horn. and who ever had the car before spliced the wires for a stereo instead of getting a wiring harness. any help is appreciated.
Old Aug 9, 2007 | 08:02 AM
sounds like a mess of electrical problems, but you probably already knew that. well first of all since you mentioned that the wired for the deck is spliced, look each one over and make sure they are connected properly, at least. (electrical tape is not considered connected properly), but that would usually lead to lighting problems. it sounds like the AC/heather assembly is pretty messed up and i would replace the whole thing, or just simply remove it, also for the seat belt problem, replace the seat belt controller computer deal under the center console/armrest, or just convert to manual seatbelts (recomended). im not too sure what you mean by losing RPM, so that could be anything. well good luck.
Old Aug 9, 2007 | 09:14 AM
thanks for the reply. well when i was talking about the rpm's, when im at a red light the rpm's sit at about 1000, then when i give it some gas the rpm's will try and bottom out but then it gets back up and accelerates
Old Aug 9, 2007 | 10:54 AM
nightkid86's Avatar
^vac leak?
Old Aug 9, 2007 | 12:33 PM
DALAZ_68's Avatar
Originally Posted by nightkid86
^vac leak?
thats wut im thinking...
seatbelts though
i also suggest manual...u loose around wut 25 pounds of equipment lol
Old Aug 9, 2007 | 11:55 PM
thatloserkidqui's Avatar
ugh...why did you tell me that...i like my auto seatbelts but i am a weight ****...crap
NickSimcheck
Feb 1, 2004 09:48 PM
Ron23
Dec 20, 2003 12:10 PM
Aznplayer911
Dec 2, 2003 11:12 PM
jonno1234
Dec 2, 2003 03:45 AM
neo84
Jun 26, 2003 11:49 AM
