no start after radio and amp instalation
Old Jan 19, 2008 | 08:39 AM
life1sastd's Avatar
here it is quick and simple, installed by 2 12's, speaker and sub amps and now it wont start. Nothing, i hear the fuel pump turn on but nothing elts. my thought i knocked something loose running the wires. any help would be apreciaded. i will be outside all day today frezing my ****ing nuts off looking for the problem. P.S. there was nothing worng before i redid the sound system.
'93 240sx se hatch, sr20 swap
Old Jan 19, 2008 | 09:04 PM
240SS's Avatar
What did you touch or where were you in the car while doing this work? If the fuel pump comes on that means the ECU is getting power.Does the starter try to turn over? If not meeter the switch on the column to assure power is being sent from it. It could just be burned out.
Old Jan 20, 2008 | 07:58 AM
life1sastd's Avatar
ran power wire from battery thought ecu gromit, under pas side carpet. spaker wires under das and down driver side. and like i said berfor the starter make no attempt to engage. battery is good, lights dont dim when i try to start, i can rol start and she sounds perfect. bang on the start to see if the selanoid fried but still nothing. found no obvious loose or unconected wires. will be breaking out the micro metter to day to test relays and switches. any ideas.
Old Jan 20, 2008 | 09:18 AM
alt and start fuse bro.. check them.... check your wiring..
Old Jan 20, 2008 | 09:38 AM
240SS's Avatar
Yea go under the hood and check your main ignition fuse and the starter/alt fuses. I blew a main ignition because of poor wiring but the previous owner and my car wouldnt do anything. It would come on but wouldnt fire up. As soon as i tried to start it the ign fuse would pop. Found out the wiring was done poorly and was causing it.
Old Jan 20, 2008 | 11:17 AM
life1sastd's Avatar
ok, so where is this starter fuse. i checked every fuse in the relay box under hood on pas side. all good, i used the multi meter not to mention visualy inspected every fuse i saw. im not new to the 240 world but is there somthing im missing.
Alteus
Jan 14, 2008 01:37 PM
sav180
Aug 9, 2006 03:32 PM
C-Walk
Dec 26, 2004 10:54 PM
bonomo
Nov 17, 2003 04:39 AM
