Nology coming out with a PDA-Dyno
Old Sep 1, 2002 | 02:06 PM
Ryan's Avatar
http://www.mmrusa.com/nologypda.htm
Put a dyno in the palm of your hand.
If you want to know the horsepower and torque of your engine, or the 0 to 60 time or even ¼ mile times and speed, just use the Nology PDA-Dyno.
It works on all vehicles 1996 and newer by connecting to the OBD II connection.
Nology PDA-Dyno includes:
OBD-Dyno Interface Box
OBD II Interface Cable
Software CD & Manual
Works on any PDA with Palm OS 3.0 and higher.
PDA hotSync/Data cable and PDA not included.
Features:
Measures:
Horsepower and torque
0 to 60 times
(and other speed combinations)
¼ mile time and speed
Fuel economy (MPG)
Display:
General engine and vehicle information
Diagnostic trouble codes (DTC)
Displays real time sensor data.
Up to two sensors can be monitored and graphed simultaneously
Up to 5 sensors can be displayed in bar-graph and analog
Displays the following sensor types:
Load value, Vehicle speed, Coolant temperature, ignition timing, Engine RPM, Fuel trim, mass air flow, intake air temperature, Throttle position, Fuel Pressure, Intake manifold pressure, Oxygen sensors (does not support Enhanced Powertrain Data)
Old Sep 1, 2002 | 02:39 PM
leiferik1's Avatar
that is bad ***
Old Sep 1, 2002 | 03:14 PM
95exlude's Avatar
i doubt its going to be accurate...
Old Sep 1, 2002 | 08:12 PM
StanBo's Avatar
I wouldn't mind picking that unit up.
I have a m125 I have not been using for a while and it would come in handy as a data logger.
TOO BAD I AM OBD I.
Old Sep 3, 2002 | 12:16 AM
spitz7985's Avatar
http://www.gtechpro.com/
Old Sep 3, 2002 | 03:02 PM
StanBo's Avatar
I like the gtech pro. But I like the fact that the PDA reads all of your available sensors off of the ECU.
I might get this for my other car. It is a 2000.
I wounder if that service plug is for all ECUs. Do you think we will have to get converter plugs?
Old Sep 23, 2002 | 11:28 AM
Ryan's Avatar
That's what I like about it too..
Old Sep 23, 2002 | 02:17 PM
Bigunitsnake's Avatar
Banned
ALTIMAS.NET OWNZ
Kami Speed
Jul 14, 2007 08:34 AM
cheappower
Jun 12, 2006 12:13 AM
Nismo253
14
Jan 23, 2006 07:35 PM
luvmy240
35
Jul 1, 2005 08:18 PM
ProjectMy240
Feb 28, 2005 02:54 PM
