Overheating, shutting off.
Old Aug 3, 2004 | 11:30 AM
Temporary's Avatar
Recently my lower radiator hose was leaking, so I replaced it. On the day I replaced the hose, I was driving around, and noticed that my car was still overheating. I stopped at a store for about 30 mins to let my car cool back down to drive home. On the way home the engine cut off on me, and I had to have the car towed home. I replaced the Water Pump, so I know it's not that causing the problem. Any ideas what could be causing the overheating or shutting off? BTW I have a 1995 240sx SE.
Old Aug 3, 2004 | 05:35 PM
Thermostat, other piping, is your overflow tank filled up? Is your radiator filled up correctly?
Old Aug 3, 2004 | 09:32 PM
Temporary's Avatar
Thanks HyJynX, it was the thermostat. Already got a new one in. Not overheating anymore. Thanks again!
Old Aug 3, 2004 | 11:24 PM
Nice, no prob.
Old Aug 16, 2004 | 12:45 PM
Temporary's Avatar
OK, now the damn thing likes to over heat when i come to stops. As long as the car is going like at least 25 it stays cool. When I slow down it'll heat up really fast and send the gauge out of the normal range. But once I start moving again the guage goes back down. The i have replaced in the past month: the radiator, water pump, upper and lower hoses, thermostat. The system has PLENTY of coolant in it. Can anyone tell me what's up?? Do i still have a damn air bubble in the system??
Old Sep 17, 2004 | 06:07 AM
TWAN's Avatar
may be the head gasket. just a thought. my honda used to do that.
Old Sep 18, 2004 | 03:45 PM
Texas240's Avatar
and make sure not to get an OEM thermo, get a performace one that will lock 'open' instead of 'closed' so you engine doesn't burn up on you.
redd100
SR
15
Oct 25, 2010 07:58 PM
USMCDrifter
Sep 21, 2007 08:25 AM
l b1 l
Sep 19, 2003 02:37 PM
DCTperformance
Feb 8, 2003 12:38 PM
sil-8-ty
Sep 14, 2002 06:44 AM
