pipes falling out
Old Nov 14, 2003 | 05:40 AM
Doba's240's Avatar
pipes falling out
you guys ever have this with your SR?
when i try to accelerate, 3 times now in 3 different locations my turbo piping came off, theres so much vibration a chick could get off sitting in my car, i hope its cause i have no exhaust, all im running right now is the downpipe.
Old Nov 14, 2003 | 05:55 AM
ProricanRacer's Avatar
I could be wrong but I just thought I'd give you whatever info I have. I had that same problem with my 3000Gt....and the reason it happened for me was because my header was not on correctly....it might be a different reason for you but just thought I let you know that it could be your headers or your tires could use a little balancing....but then again.....the no-exhaust might be the key to the problem as well.
Old Nov 14, 2003 | 06:41 AM
Doba's240's Avatar
If i had on an aftermarket exhaust manifold id have that checked but its stock so i think it should be fine, and as for my wheels needing balancing, id notice it in the steering wheel and its fine.
thanks for the reply and i hope its only the exhaust too.
Old Nov 14, 2003 | 09:58 AM
It might be the exhaust..or it also could be your mounts are worn out or you misplaced the engine.
Old Nov 14, 2003 | 10:18 AM
Doba's240's Avatar
well its an SR out of a 98' 180sx so i wouldnt think the mounts are worn out, unless the previouse owner did some crazy *** ****.
misplaced the engine? hmm didnt know that could be done, i just put the screws from the engine mounts into the hole, seems simple.
Old Nov 14, 2003 | 10:36 AM
i meant not tight enough..or the crossmember could not be tight enough maybe ur 240s mounts?
Old Nov 14, 2003 | 10:56 AM
Doba's240's Avatar
hmm yeah maybe they need to be re-tightened, ill do that this weekend
Old Nov 17, 2003 | 05:02 PM
Jonas's Avatar
turbo piping as in down pipe?????? or intercoolr pipings???
Old Nov 18, 2003 | 05:36 AM
Doba's240's Avatar
intercooler piping but never fear i solved it over the weekend.
its all good now
Old Nov 18, 2003 | 10:53 AM
focalguy's Avatar
Just curious Doba, but could you tell us what you did to solve it? Just in case someone else has the same problem.... thanks
Old Nov 18, 2003 | 10:59 AM
Jonas's Avatar
be sure to use good silicone connectors, tighten them down with hose clamps and if you can weld or know someone who can weld... BEAD the ends... and if your still blowing intercooler pipes shoot me
Old Nov 18, 2003 | 11:28 AM
Doba's240's Avatar
Basically what Jonas ^^^ there says good silicone, i was told the engine moves quite a bit when you step on the gas, so not only does the silicone have to be tight but it needs some slack, some movement, my stuff was pretty rigid and every time the engine moved hard they came off, i just messed around with the piping and now its been perfect for 3 days.
lets hope it lasts.
crazy9ceguy
Jun 6, 2004 03:53 PM
jmack240
Apr 29, 2004 08:00 AM
cutter
Mar 23, 2004 07:18 AM
NightXCZ77
Mar 8, 2003 11:45 PM
Darvocet
Feb 9, 2002 06:55 AM
