problem with a 91 240
Old Mar 14, 2004 | 05:21 PM
roosiman2004's Avatar
alright im thinking of buying this 91 240 fastback in my town but it has one problem maybe someone could help me with. it has an automatic with only like 110,000 miles on it. the problem when i step on the gas its real hard to push and when you do push it, it seems like it takes awhile to get the car to move and the only time it moves is when you push the gas hard. i really cant tell if there are noises because of a hole in the exhaust that will be fixed after i buy it. if anyone knows that would help alot to tell if it would be worth fixing. thanks
Old Mar 14, 2004 | 05:26 PM
devnull's Avatar
The throttle cable is either stretched or needs lubrication.
Old Mar 14, 2004 | 08:13 PM
alright ill take a look at it. any other things it might be i case thats not it?
Old Mar 14, 2004 | 08:58 PM
tallic_red240sx's Avatar
Could be yer aiv.....Remove it and see what happens
Old Mar 14, 2004 | 09:26 PM
this is gonna sound dumb but whats an aiv?
Old Mar 14, 2004 | 10:20 PM
nevermind figured it out
Old Mar 15, 2004 | 09:39 AM
drnovascotia's Avatar
dood
do a tune-up on her, and fix the hole in the exhaust, thats gonna make performance bad.
The hesistation if the tune-up doesn't fix it can be from a clog in the cat, clog in the intake, many things. Clean your throttle body, maybe some seafoam, helped me.
Dr.
Old Mar 16, 2004 | 05:10 PM
Here Is Where The AIV IS....
Old Mar 16, 2004 | 05:13 PM
heres all the parts removed....once you have these removed plug the 2 large vacuum hoses with bolts and clamp em off.Theres also two small lines that go in from the bottom near the sensor that need plugged.
Old Mar 16, 2004 | 08:13 PM
alright ill try those after i buy the car like friday or monday when ever the check clears
vortxxe
Apr 29, 2006 05:22 AM
uvamosk
Aug 12, 2005 07:31 PM
90,240sx
Dec 22, 2003 08:33 PM
Thieu
Aug 26, 2003 05:09 PM
240SEX
Oct 27, 2002 03:32 PM
