rear end rumble!
Old Aug 24, 2005 | 03:44 AM
scsi's Avatar
rear end rumble!
okay, when i take a turn and try to accelerate out, if i give too much gas (it isnt much), and especially if i try to power over, get a rumble from the rear end. i thought it might be the subframe bushings so i did a search and discovered that many people have a loud thump/clunk and the problem is so bad that it happens to them sometimes even under normal acceleration, shifting, "applying heavy load" to the rear end. my problem certainly isnt as serious as that, but i was wondering if it was similar, and if the subframe spacers/collars would fix my problem?
i was looking into the Specialty Z spacers by Greg Dupree which are only lower spacers for $60. i also saw on jspec.com there is a full set (top and bottom) by P2M, they are being sold for $95. would i notice a big difference between the P2M full set top and bottom, or should i just go with Dupree's bottom spacers? thanks!
Old Aug 24, 2005 | 04:23 PM
scsi's Avatar
bump
plz help me!
Old Aug 24, 2005 | 11:04 PM
scsi's Avatar
aw cmon, anyone?
Old Aug 24, 2005 | 11:59 PM
steve 14's Avatar
do top and bottom
you can find them for $65
Old Aug 25, 2005 | 01:58 AM
scsi's Avatar
where can u get them for $65? cheapest i found was $74 from spl parts, hmm
will this fix my problem? is my problem even related? anyway, thanks for the first real reply haha
Old Aug 25, 2005 | 09:40 AM
might be your subframe bushings - or your subframe might be a little loose (don't ask how that happens).
$65 is Ebay. You don't need to go brand name for subframe collars.
Old Sep 23, 2005 | 07:32 PM
Xstr8_edgeX's Avatar
Hey it might not be your subframe spacers, it could be your rear diff....You could have gotten water in it...you would be able to tell if you open it up and there is rust present on the gears...or it could just be going out on you
Old Sep 23, 2005 | 09:00 PM
prjkt240's Avatar
Definetly sounds more like a problem internaly like he said /\. A rear sub frame issue would definetly be more of a thump/clunk noise. A grumble wouldn't describe a sub frame problem, at least not in my opinion. Although anything is possible. I think you should get some sub frame spacers for the simple fact that if nothing else at least it will stiffin up that rear end. I would go with a top and bottom set. I purchased Kazama spacers for my '95 to get rid of my thump noise. They were top and bottom. They are a little up there in cost, but well worth it. I don't know how some of the budget spacers are, but the Kazama "upper" spacers have a cut out so you can slide them into place. Install was a snap, about 5 min. only because I am a technician and have access to a lift. On the ground on stands it may be a little more difficult. Try to do a rear diff. service too. Rear diff. service is like pwer stearing fluid and brake fluid to most people, they never think to change it. Cars with the age and milage as high as most 240's and the fact that we buy them used that way, we don't think to do it anymore than the previous owner. Drain and fill that fluid and see if it doesn't help. PM me if you have any questions.
Old Sep 24, 2005 | 01:13 PM
steve 14's Avatar
how the **** is water going to get in there
all subframe collars come with the slit unless you get the soild one's witch involves taking the subframe off
Old Sep 24, 2005 | 06:02 PM
TWong1200's Avatar
There should be a vent on the higher portion of the pumpkin housing to let it breathe. Could get in through there.
Juiced
Apr 2, 2008 11:39 PM
rrh22
Sep 11, 2003 10:03 AM
Roaland t.H.T.G
Jul 31, 2003 02:17 PM
dkdeleon
Mar 28, 2003 03:44 AM
180SXcoolguy
Mar 6, 2003 12:53 PM
