Rear Taillight strip won't light (1990 fastback)
I didn't see a technical forum so I posted here. That third taillight (the thin one that runs along the top of the hatch) won't light when I push my brakes in. My other brake lights work fine and so do my turn signals and headlights, etc. I've replaced the bulbs and checked all the fuses in the car that seemed to relate to anything having to do with lighting, but no luck. Is there another fuse I'm missing? Perhaps one in the engine bay or anything else I missed? Thanks in advance.
if the fuse and connectors are fine... (test with a ohmeter or a curcuit tester) then it's probably your ground. That's how i fixed mine. Just rewire a ground to the defogger or rear window wiper circuit and it'll work perfectly fine. Just go out and buy some wires, wire cutter, electrical tape and as for tools all you need is a screwdriver to attach the ground.
240sd
Mar 19, 2006 01:17 AM
Strizzy
13
Aug 26, 2003 09:30 AM
flarearrow
Sep 24, 2002 09:06 PM
