Rev to 3000 and hear clicking??
Old Dec 17, 2007 | 06:56 AM
your thinking about his way to hard man. its a heat shield held in with a bunch of 10mil bolts. jack the car up when the motors not hot. and remove it. it'll stop all of that rattling and whatnot. then your good to go.
Old Dec 17, 2007 | 09:55 AM
Besides, you dont need the heat shield anyways, so might as well get rid of it.
Old Dec 17, 2007 | 11:51 AM
xsubxwooferx's Avatar
After doing this....will this 100% stop that problem? Like hmm I'm just not sure if its "clicking" on what me and everyone are thinking of....Like when I drive right by a car then shift gears I can hear the sound barrier off that car and it sounds like someone ripping paper except louder I guess.
Old Dec 17, 2007 | 01:08 PM
yarou's Avatar
Seriously, clicking from your car? it could be A THOUSAND DIFFERENT THINGS, have a friend rev the car while you look and listen. We can't really help you here or you give for sure answers for obvious reasons
Old Dec 18, 2007 | 12:36 AM
Okay, if its your heat shield making the noise and you take it off it will get rid of the problem. If you take it off and it does not fix the problem then it is something else and you have not hurt the car, and we can go from there. Just get rid of the heat shields. Now.
Old Dec 19, 2007 | 07:12 AM
Ok last question before I "try" and take it off......Is their a reason why its on their if everyone has it off? Can any bad news happen while it is off? Say I put some aftermarket product around it and heat gets to the steel and starts melting or something I dunno.And its off but its still making that noise.
Old Dec 19, 2007 | 10:17 AM
could be alot of things, just go through and eliminate possibilities. one thing to consider is that when the car is in neutral there is no load on the engine. heck it could just be your shifter bushing or clip
Old Dec 19, 2007 | 10:31 AM
Well I dont think it is any of the heat shields since its not clicking at 3000RPM...just like grinding for like less than a second.Whether I shift or not. Also if I am pass 3000RPM and slowing down without changing say 3rd to 2nd, it makes it again right when it hits that 3000RPM mark.
Old Dec 19, 2007 | 11:45 AM
Taking off the engine heat shield will absolutely not hurt the car. My hatchback never had one and I owned that car for a year. I cant speak for the other shields, but I am absolutely sure that taking the header heat shield off will cause no damage.
Old Dec 19, 2007 | 12:43 PM
Now can it be the down pipe heat shield? Can someone give me a pic of where its at? I googled everywhere and couldnt find pics..just other forums about it.
Old Dec 19, 2007 | 04:16 PM
  #26
look underneath the car, it's pretty easy to spot. it's not actually a "downpipe" per se
Old Dec 19, 2007 | 07:44 PM
  #27
i looked under their alot I just dont know what I am suppose to be seeing.
Old Dec 19, 2007 | 08:39 PM
  #28
Dont know what kind of car this is, and on the 240 it will be further up by the engine, but this is generally what it looks like.
Old Dec 20, 2007 | 08:45 AM
  #29
Ah hell I remember seeing that....... its where it curves up to the engine ...hard as hell to get to.
Old Dec 24, 2007 | 08:36 PM
  #30
smoken805s14's Avatar
is it alright to take off da heatshield from underneath the car where the exhaust tip is by....or do u need that one?
