RPM's 2k-3k dead spot
Old Oct 3, 2005 | 12:24 PM
onevia's Avatar
Hey all,
I searched for a bit but could find no real solution.
'92 240 coupe manual. AEM intake
So the problem is on my rpm band in 1-3 gears the rpm's "struggle" through 2k-3k, and when it hits 3k it "pops" like it was normally suppose to accelerate. I put an intake on about a month ago;everything's been fine. I had a kill switch installed by a local shop two weeks ago, they messed with the electrical wiring I believe; although it seemed fine for a week after. I recently drove to Vegas from SoCal and all was good drove 'bout 85-95 the whole way. The problem occured after this trip. When I got back I changed my oil. The problem still persisted. I checked all the lines and everything is attached and fine. I had my car on and listened to the engine, it sounded like something was a little loose. The rest of my power in the powerband is still there 35k-6k pulls like normal. The smog station could not test my car cause of the rpm's not staying persistent.
I really hope that it's a very basic 'common' problem.
Any info is greatly appreciated.
Thanks
Old Oct 4, 2005 | 12:12 AM
lrb_2000's Avatar
mine does the same! ... like when you shift, does it kinda hesitate, then it feels like the power kicks in all the sudden?
Old Oct 4, 2005 | 09:55 AM
onevia's Avatar
Exactly!
How long has it done that for your car?
........why is no one replying?
Old Oct 4, 2005 | 11:47 AM
lrb_2000's Avatar
It did it too my 89 coupe too... I acually think, and have been told, It might be the clutch.. like it's not catching at first or something... because if I shift @ 6k, then second gear hits around 4k or something, it doesn't do it... only if I shift early, and give it gas it like.. bogs down.. :|
melchior
Sep 18, 2007 09:20 AM
twofotisx
Jan 4, 2005 11:20 AM
4984 5fsdskfvjdsntr4
Southeast
Mar 13, 2004 06:22 AM
RoadblockTDX
Apr 11, 2003 02:07 PM
Import Fanatix
Northeast
39
Nov 8, 2002 02:28 PM
