shift knob
Old Nov 9, 2004 | 11:23 AM
C-Walk's Avatar
Question shift ****
i head somewhere that the 240's shift **** is counterweighted so if you changed it it would grind in third gear when speed shifting... is that true? and if it isnt how the hell do i get the damn stock one off of my 95 240? it's impossible.
Old Nov 9, 2004 | 11:44 AM
Re: shift ****
I don't know about the whole "counterweight" thing, the stock shift **** feels normal to me... as for removal,
s-e-a-r-c-h.
5 seconds got this:
http://www.club240.com/forums/showth...ght=shift+****
Old Nov 9, 2004 | 11:49 AM
Don't know bout counterweighted, but they are heavy as hell.
My buddy changed his out to a regular no name shift **** and had no problems.
Old Nov 9, 2004 | 04:01 PM
CowboyTurbo's Avatar
don't worry about it being "counterweighted", the stock shift **** is a bit heavy, but there's no reason why changing to any other aftermarket shift **** would cause any troubles in shifting. As for not being able to unscrew it, there also shouldn't be an particular reason why you can't get it off~ just unscrew counterclockwise. If it's stuck and not budging, try spraying WD40 near the grooves 'n' tapping on it lightly w/a hammer... g'luck
Old Nov 10, 2004 | 04:08 PM
C-Walk's Avatar
thanks, much apreciated
Old Nov 11, 2004 | 07:32 AM
Joel SX's Avatar
Yep! tap it lightly, my brother had an protege ( I know its not related) and he was trying to get the shift **** to go in and he taped it down hard and it landed on the street.
But I doubt this will hapend in a 240 because the transmission is right below it. Just be carufull. the shiftknob might not be expensive, but the whole asembly is.
Old Nov 13, 2004 | 02:56 PM
C-Walk's Avatar
thanks alot guys... i had to go in hulk mode with the vice grips to get that fricken thing off but its all okay now, got my carbon fiber ractive **** back on and i'm good to go... there is a little bit of free play though when i pull up on the shifter is this normal it never did it in my old civic hatch, though this was happening when i bought the car so i dont know...
hkspeed
Oct 1, 2005 05:34 AM
wesc
Nov 12, 2003 04:35 PM
Bryan
Aug 24, 2003 03:40 PM
89240sxmup
Nov 17, 2002 03:23 PM
Jonas
Oct 6, 2002 01:20 PM
