speedometer not working
Old Jun 21, 2006 | 11:52 AM
s13drag's Avatar
hi i have a 1990 s13(stock) automatic and my speedometer is not working do i need just a sensor or a new cluster
Old Jun 22, 2006 | 07:31 PM
ReigH's Avatar
does everything else work on your cluster? your speed sensor is probably dead
Old Jun 23, 2006 | 05:11 AM
s13drag's Avatar
the speedometer does not work other than jump around once in a while and the odometer works for a few miles every couple hundred miles or so and everthing else works fine
Old Jun 23, 2006 | 08:19 PM
NismoSX's Avatar
try taking the gauge cluster out of the dash, checking all the wiring make sure nothings come loose, and check under the hood to make sure the other end of your speedometer wire is running into your transmission.
i would check to make sure its in your transmission first , since thats the easiest thing,.
in case you dont know what im talking about:
your speedometer cable has an end with a gear on the end of it, this simply plugs into a hole in the top of your tranny, which allows the gauges to register your speed and miles, your problem may very well be that youve hit a bump or something, and that wire has juggled loose over time, and may be half way in there so every once in a while itll catch and jump. but like I said, check that first, its a lot easier and simpler than pulling the whole gauge assemly out of the dash.
Old Jun 24, 2006 | 10:15 AM
s13drag's Avatar
ill try that thanks for the info ill let you know if it works
Old Jun 27, 2006 | 03:45 PM
S13DET's Avatar
Whoot I am glad some one asked this...I have the exzact same problem...with the exzact same car 90' 240 auto, except everything on the cluster works right except for the Spedometer...
Old Jun 28, 2006 | 05:25 PM
touge4life's Avatar
O.K? If you have a SR20DET in your car, the 89-90 cluster wont work. You have to get the newer model ones like I had to. If your cluster is digital, then you'll have to take it apart and replace the capacitor behind it (stock non SR). For some reason they just burn out. I suggest that you go and get a newer model 240 with an analoge gauge, it should work, it's much easier then trying to fiqure it out. P.S. there's no speedometer cable for those of you who don't know.
Old Jun 28, 2006 | 05:28 PM
touge4life's Avatar
I forgot there is a speed sensor on the trany, check it too.
slepper13
Nov 9, 2005 07:57 PM
n240sxfnatic
Sep 19, 2005 07:08 AM
EDog
Aug 11, 2005 06:48 AM
SilvaPwr
Jun 25, 2003 10:35 AM
rps13
Apr 10, 2003 12:48 AM
