Speedometer problems
Old Oct 25, 2003 | 11:18 AM
Rittmeister's Avatar
OK guys, I've got a problem. 1990 Ka24E.
I have the infamous non-functioning HUD problem, HOWEVER I also had NO lights in the dash cluster. The lights in the radio/HVAC controls worked, but the only thing working in the gauge cluster was the tach. The odometer didn't work either.
Fast forward to today. I got a spare cluster and HUD from another S13. I put it in before realizing that it was from a DOHC car, so the tach doesn't work. My own fault, however the HUD and speedo on the new cluster also aren't working. My question is this: are the speedometers also different between SOHC and DOHC cars? Or is there a speed sensor or something that is either bad or is different between the engines? The backlighting is working now, so that's OK. Don't know if the new odo works, I don't want to drive it until it's put back together.
To sum up: neither HUD nor speedo are working, even after putting in a new cluster. Everything else is, except for the tach, which I know how to deal with.
I really need help. My dash is all over the passenger floor right now until I get this resolved.
Old Oct 25, 2003 | 11:46 AM
fist's Avatar
have you checked all your lines?
Old Oct 25, 2003 | 12:11 PM
By lines do you mean electrical connections? Where would I check, other than making sure the plugs are secure in the rear of the cluster?
Old Oct 25, 2003 | 10:01 PM
Shortened version: are the SOHC and DOHC speedometers different? Also, will the speedo remain completely blank if the speed sensor is bad, or will it read zero?
papakiet
Nov 16, 2004 07:27 AM
skyline_123
Jun 30, 2003 02:11 PM
SilvaPwr
Jun 25, 2003 10:35 AM
dennis
Feb 14, 2003 05:09 AM
Brett Wreck
Oct 7, 2002 06:21 PM
