Starting problems
Old Apr 24, 2005 | 09:52 PM
white_rms13's Avatar
Starting problems
Ok I have a 1991 240sx no engine mods.. I got a problem starting my car. This happened gradually. One day it just wouldn't start for some reason.. Then the problem just got more and more frequent over time. It cranks and everything but it doesnt start. I replaced my spark plugs. That didnt help too much. When i replaced them I got the engine started but when i turned it off and tried to start again nothing.. Any ideas?? thanx
Old Apr 25, 2005 | 10:00 AM
98cwitr's Avatar
go get your alternator and battery tested first. I had the same problem (but most of the time my car wouldnt even turn over!!) and it ended up being the starter.
Old Apr 25, 2005 | 01:30 PM
Atown 240's Avatar
yeah, i checked my battery and alt but they were fine. My engine sometimes just like clicks but wont turn over. I think it's my starter. Cause if i try like 10 times it eventually with crank. It happens once in a while
Old Apr 25, 2005 | 01:40 PM
if it wont start, try banging on your starter, and then starting it, if it starts up then its your starter
Old Apr 25, 2005 | 09:14 PM
Can you show pics of what the starter looks like?? And where is it located? under the car or hood?
Old Apr 26, 2005 | 12:54 PM
98cwitr's Avatar
crawl underneath the passengerside wheel...the starter is crammed right in front of the tranny and bolts onto the transmission housing via the engine block. I should have mentioned tapping the starter, thats how I started my car for two weeks
Old Apr 26, 2005 | 05:10 PM
twofortyessex's Avatar
also check the wiring for any shorts, and the switch on the clutch pedal (if its manual) and make sure it makes a good connection.
Old May 9, 2005 | 05:04 PM
Ok Im pretty sure its a fuel problem. Because it started not too long ago. It was very random too. But anyway i made the most of it cuz it was raining. So i went drifting, but then it was cut short.. I noticed when i reached a certain point of pushing the gas pedal down it would start sort of "choking" (best way to explain).. It was like getting little spits of gas..Then when that happened, the car would shake violently.. Like when u tap the gas in first gear..(just not THAT violent) Kinda like a spray of gas instead of a clean stream... So could it be injectors?? or maybe the fuel pump.... Should i get some injector cleaner??
Old May 9, 2005 | 05:36 PM
98cwitr's Avatar
injector cleaner...check your fuel filter for starters...let us know what happens
Old Sep 1, 2005 | 04:25 PM
WOW after so long.... i just ended up going to a shop. He said it was the ECU... LoL but now im happy.
mcampbell26
RB
Jul 28, 2008 02:53 PM
NiNJA323
Jan 21, 2005 10:50 AM
C-Walk
Dec 8, 2004 02:23 PM
RS250 Chester
Jan 18, 2004 02:29 PM
Rittmeister
Sep 5, 2003 09:03 AM
