temperature sensor location
Old Jul 15, 2004 | 07:37 PM
driftings13's Avatar
Question temperature sensor location
HI
I need to wire a water temp gauge and i need to know where is the temp sensor on the ka24de !
plz need advice too on how to wire this too
thank
Old Nov 30, 2004 | 06:29 AM
Re: temperature sensor location
Originally posted by driftings13
HI
thank
The OEM temperature sensor is near the upper radiator hose fitting, on the intake manifold/block area. If you're standing facing the engine in front of the car with your hood up, find the upper radiator hose and follow it along all the way until it stops at the engine. keep going along the same route and you'll see 2 sensor screwed into the metal part where the radiator hose attaches. One sensor is larger than the other; the smaller sensor neares the engine has one wire coming out of it - the small sensor is the OEM temp sensor.
However you're better off running a seperate temp sender, using an adaaptor tube spliced directly into one of the radiator hoses. This is a common method; hopefully someone can offer another alternative if it's been done another way.
Old Nov 30, 2004 | 08:58 PM
carofchoice's Avatar
what he said...tapping into the radiator hose is by far the most common.
Old Dec 4, 2004 | 11:00 PM
BlitzDriftGTR's Avatar
Yea what they both said
jsp
Jun 25, 2006 05:40 PM
ToRu
May 13, 2006 10:50 AM
jt1583
Sep 28, 2005 09:33 PM
TheBull
Nov 14, 2004 12:07 PM
