top end noise (not timing chain)
Old May 27, 2005 | 01:20 PM
GreenPunkBlood's Avatar
I have found out that my engine dosent have rod knock. The noise seems to be coming from the cyl 2 or 3 area and around where the head meets the block. It still runs strong, and ony makes the noise when i first start the car and at 2k and after 3.5k....
Old May 27, 2005 | 04:37 PM
Slidin240's Avatar
it can be your valves. maybe you bent them. i had a friend who had the same prob and i checked it and it was 3 bent valves
Old May 28, 2005 | 08:35 AM
it the noise the valves hitting the head or the piston? Either way, is it safe to drive the car?
Old May 28, 2005 | 08:40 AM
Slidin240's Avatar
you can drive it but your prob going to be messing that head up even more (mite not be fixable after a while) and it will get worse. I recomend gettig that fixed ASAP. The valves are in the head and the noise is when the piston is smacking into the valve. ive seen some cars that ran on that for a wile but when they went to fix it nuttin could be done but to get a new head cus it was cracked.
240sx'in
Dec 27, 2005 12:04 PM
bosozoku s14
Apr 17, 2005 07:01 PM
twistedriver
Jun 15, 2004 10:50 PM
Imungree
May 15, 2004 04:16 PM
spitz7985
Oct 8, 2002 03:34 PM
