Tune up
Old Jul 8, 2006 | 08:21 AM
NJKnight's Avatar
Tune up
Hey wassap I want to do full tune up on my car what do I need to change and what would be the best brand. If any body know some kind of web site, basically a break down for the full tune up that would be nice.
Old Jul 8, 2006 | 08:31 AM
i found this website. it gives you everything you need for a full tune up and you can buy em online. http://www.courtesyparts.com/S14_tuneup.html
Old Jul 12, 2006 | 02:12 PM
Badazz_240's Avatar
My advice is to take the info from that site, and buy the stuff yourself at an auto parts store.
$9.50 for a spark plug?.....
Although, some of that stuff is pretty reasonably priced.
Get your oil and oil filter/air filter at Wal-Mart, because its cheaper
Old Jul 14, 2006 | 04:43 PM
Joel SX's Avatar
Here's my list to my 93 240sx Coupe:
piston rings
rod bearings
gasket set
tranny gasket set
rear and front tranny seal
tranny filter change
fluid flush
diferential seals and flush
o2 sensor change
new resonator, mufler and cat
injector flush
fuel filter
gastank filter replacement
pump inspection and cleaning maybe
fuel lines replacement
all ruber vacum hoses behind engine replacement
vacum lines, brake booster, boots inspection/replacement
sparkplugs, cables, distry change
coil upgrade to NGK
**** N polish
seafoamign the whole intake
3 belts
timign chain + guides
fan clutch
brake fuild change, recharge A/C, top PS, Flush radiator
new wiper noozles and blades
engien mounts
Engine temp sensor and oil level sensor
Engien stabilizer shocks
air filter K&N
clean all EGR realted stuff
groundign kit
new suspension Bushings/ rubber thingy's
aligment, balance of tires
re-paint body
new hood, fix rust on roof
Weather proofing rubber seals all new, everyone of them
resurface dash with fiberglass
new seats, some sort, shift ****
new roof cover inside
new carpet and floort mat carpet set
foot pedal covers
steerign wheel
Old Jul 14, 2006 | 07:47 PM
jackyliem's Avatar
man that's a rebuild. not tuneup
Old Jul 14, 2006 | 08:38 PM
SRWHAT's Avatar
Originally posted by Joel SX
Here's my list
**** N polish
Old Jul 14, 2006 | 11:45 PM
Badazz_240's Avatar
Well, although quite extreme in terms of a tune up, it is good "making your car like new" material
Somehow, I don't recall repainting your car and refinishing your dash being part of a standard tuneup?
BTW: You shouldn't replace your fan clutch, you should swap in dual electric fans... just my .02
Old Jul 15, 2006 | 12:17 PM
NJKnight's Avatar
I agree Badazz_240 100%
Old Jul 15, 2006 | 01:49 PM
re037's Avatar
ROFL
stick with the basics
dist cap, wires, plugs
all fluids flushed
all filters
seafoam
o2 sensor
and have the car checked over for everything else on joel's list and replace as needed
Old Jul 16, 2006 | 09:05 AM
explictness's Avatar
Is the S14 tune up the same as the S13? or will diffrent parts be needed?
Sorry i'm new here and i'm getting a S13 Next week so i am learning some things still.
Old Jul 16, 2006 | 08:41 PM
Darkvillin's Avatar
i have an s13. i replaced the dist cap and rotor = $34.00 at pep boys: check to see which distributor u have as there are two kinds, spark plug wires = $52.00 cheepie kind, plugs = $16.00, and an air filter = $9.00. this of course made a very big difference and gave me the awsome gas mileage i used to have. you dont have to go crazy.
Old Jul 16, 2006 | 08:44 PM
dkdeleon's Avatar
**** N polish
Where can you get that done and how much does it cost???
LOL LOL
thegary
Mar 4, 2004 12:35 AM
thegary
Sep 19, 2003 09:52 AM
EAGLE 5
Aug 14, 2003 07:39 PM
StanBo
Northeast
17
Sep 26, 2002 09:51 PM
Jonas
Sep 23, 2002 11:12 AM
