what's in your crankcase?
Old Jul 10, 2008 | 03:10 PM
i'm a curious person and i don't believe this has been addressed here so why not let everyone here know. in my jetta i use 5w 30 castrol gtx high mileage, i've used castrol gtx 5w 30 or 10w 30 for years on just about every car i've ever changed the oil on.
my 240 gets special treatment however because it gets mobil 1 10w 30. i use mobil 1 because it quiets the chatter of the lifters considerably. although i'm planing on switching to royal purple though next time i change the oil.
Old Jul 10, 2008 | 03:18 PM
also Mobile 1 cleans your motors i used 5-30w Mobile 1 synthetic oil on my SR with OEM oil filter.
but now im switching my oil to 5-30w Royal Purple i have the oil already just need to drop my SR in my new Shell.
Old Jul 10, 2008 | 03:29 PM
Why royal purple? it really isn't all that great from what i've heard. I use mobil 10w30 as well
Old Jul 10, 2008 | 03:39 PM
k_wakasugi's Avatar
Same. Mobil 1 10w-30.
Old Jul 10, 2008 | 05:28 PM
good question, after all it's like $8 per qrt vs the $7 and change a qrt for mobil 1. so here's one reason.
Edit: as it turns out the price is about the same on line i guess that guys at baxters just want to make more money off people.
the funny thing is that if you watch infomercials about other oils and oil additives they all use the same machine to prove that their oil or additive is better than the competition.
Old Jul 10, 2008 | 07:04 PM
i run royal purple.. a simple test you can perform...
take a normal oil and rub it in between you fingers... in a matter of minutes it will dry up..
take royal purple and do the same thing, it will sick around for awhile. basically you want anything that will coat your parts.
ps
wash your fingers before you touch you girl or boy friend.
Old Jul 10, 2008 | 08:26 PM
nice vid but i only paid $7.30 a quart for my Royal Purple
Old Jul 11, 2008 | 05:48 AM
acfalconhawk's Avatar
my car burns oil so i use 20w-50 Castrol high mileage oil. it really helps slow down the burn. and I got like 5 quarts for under $15.
Old Jul 13, 2008 | 01:05 PM
OutToWinPAHC's Avatar
Royal purple is also much older for cars over 15 years approx. The reason is the metals and friction points were based off of old stands of oil. Over time the chemical properties were changed because of environmental reasons. The newer additives don't always work as well. For example if you look at the top of a new oil vs royal purple or a diesel oil you will notice the similarity between diesel oil and royal purple, and the properties of the newer oil is much different.
Cars with flat tappet cams should use oils with the older lubrication additives
Old Jul 13, 2008 | 01:46 PM
it's my understanding that any synthetic oil is not recommended for older or engines that have yet to be broken in. so royal purple in not for ever one. there are other reasons that should be taken into consideration when deciding to use synthetic oils or non synthetic convectional, or even a blend of the two.
Sleeperella
Nov 19, 2005 11:02 AM
2fast4y0u
Sep 22, 2005 02:35 PM
Bryan
Sep 13, 2005 11:45 PM
ArticDragon
Jul 11, 2004 09:19 AM
Rynxprs
Mar 4, 2003 12:53 PM
