wiring trouble with engine swap
I recently swapped the KA24DE out of a 92 s13 with an automatic into an 89 with a manual. I followed the swap guide on zilvia.net and changed the plug to the main harness like the guide said. the damn thing won't crank.
there is also a the plug to the A/T harness that is different than the one to the M/T harness. can I just swap that plug.........if so what wires connect to what?
please help.
also please no smart *** answers, i've tried every source that i could think of. and come up with nothing helpfull
please help.
Your using the OBDI ecu right? Are you using the OBDI harness? First check if you ecu is getting power. Check your firing order. Forget it........you need some pics and need to be more spacific for us to help you out.
drew935
West Coast/Hawaii
Mar 28, 2004 11:36 PM
SilviaJai
Sep 23, 2003 07:36 AM
