How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Wiring question
Old Aug 24, 2010 | 06:31 PM
Originally Posted by driftapimp
a 40 amp relay
charged with a power wire from batt
pin 87 12v frm batt
pin 86 ground
pin 85 switched fuse or ignition wire
pin 30 is output to fan..
put one relay per fan
if you do this, 85 will be what you connect to the ecu. the problem is that it might be too much of draw, which could fry your ecu. i recommend you use a temp sensor to be safe.
Old Aug 29, 2010 | 12:01 AM
You can run the trigger to a stand alone switch not even factoring the ecu in. Throw a led indicator up there and call it a day. don't input anything else into the ecu then is already needed. You will expereince little to no voltage drop.
boosted-alty
Feb 15, 2007 12:08 PM
180sxfan
Sep 15, 2005 09:20 PM
TypeOne
Dec 20, 2004 06:09 AM
DaPCWiz
Nov 20, 2004 11:59 PM
j-z
Nov 16, 2003 03:54 PM
