240 problems
Old Oct 21, 2005 | 11:51 AM
akirassil40's Avatar
240 problems
my 240 keeps its idle normal for a while then it goes up to 1500 for a long time when i have it in neutral it does it violently sometimes like from 700 to 1500 rpm really quickly...any ideas on what the cause of it might be?
Old Oct 21, 2005 | 01:41 PM
Tanshin's Avatar
Manual or auto? Any check engine light coming on?
Old Oct 21, 2005 | 04:25 PM
manual... it came on and it turned it self off... at one point the read out was ping sensor... but that stopped..
Old Oct 25, 2005 | 06:52 AM
ECU code check will help here.
Old Oct 30, 2005 | 01:38 AM
185db's Avatar
I have noticed before that if a code stored on the computer is not current, then it may not show the code to you manually. You may want to take the vehicle to a pro to diagnose it for you or at least invest in a code reader. It sounds to me that a sensor my not be functioning properly, or it could be simpler like a stopped up catalytic converter. BTW by manually I mean using the method of reading the blinks of the check engine light.
Old Oct 31, 2005 | 04:48 AM
240sxnv's Avatar
i havent done much research but do nissans have a IACV ( idle air control valve) ? thats what sounds like to me
Old Nov 1, 2005 | 03:37 AM
wikd240's Avatar
yes they do have a iacv... also look into broken or cracked vaccum lines or air leaks in the intake...
Baby_Drifter
Jan 19, 2007 02:07 PM
1979rs/z28
Dec 23, 2006 05:34 PM
slo9012Vde
Jul 18, 2004 07:14 PM
Maroon240
Apr 24, 2004 09:58 PM
SlydeSHO
Nov 13, 2003 12:06 AM
