AC belt and Front Crank Seal
Old Oct 24, 2004 | 06:59 AM
EvansCars's Avatar
I just bought a 1990 240sx and I'm doing a couple things to it. First off I need to put on a belt on the AC compressor. I was told that there is a part that spins freely that the belt goes around. Then the second part is the clutch. If that spins freely then the clutch isn't locked up and the compressor is fine. I think I found the clutch. There are 2 flywheel type things that the belt goes around. The top one is larger than the bottom one. I'm guessing the bottom one is the clutch?
The second thing I need to do is replace the front crank seal. I was told to take the belts out, take the radiator out, then take out a 24mm bolt and tap on the inside of the crank seal and if I'm lucky it will come out.
Is all of this information correct? I want to make sure before I start doing things.
Old Oct 31, 2004 | 01:28 PM
EvansCars's Avatar
Ok I am much closer to the crank seal. I just need a quick answer from someone... is the crank seal behind the pulley that is on the bottom or is it behind the clutch fan?
Old Nov 10, 2004 | 01:07 PM
stinky.180's Avatar
behind the crank pulley
Old Nov 10, 2004 | 02:06 PM
SHIFT_speed's Avatar
Let me see if I can find a pic from a customer car
japanesenut
SR
Sep 17, 2009 11:36 PM
positron
Jul 26, 2007 04:22 PM
Purple240
Sep 21, 2005 11:23 AM
chriskelchner
Sep 16, 2004 07:41 PM
Mach5
Apr 28, 2003 05:06 PM
