advanced timing
Old Dec 19, 2004 | 01:27 PM
franman s13's Avatar
advanced timing
where are the timing marks on the crank puley? a pic would be perfect
Old Dec 19, 2004 | 04:03 PM
never mind just had to clean the pulley a little, but now i need to know where the mark on the block is that points to the marks on the pulley. i thought i new where it was but when i checked the timing where i thought the mark was the noches on the pulley didnt line up, until i turned the dial on my timing light to 60 degreas advanced. so i must not be looking at the right mark.
Old Dec 20, 2004 | 02:48 AM
there's supposed to be a needle-type pointer just above the crank pulley - not a mark on the block itself. You can see the needle pointer from the right side of the crank pulley. This needle is supposed to point to 20 degrees advanced. There are 6 marks on the crank, with the second mark being a different color from the rest. The marks are as follows (read from left to right):
- 5 degrees before TDC
- (different color) top dead center, piston #1
- 5 degrees after TDC
- 10 degrees after TDC
- 15 degrees after TDC
- 20 degrees after TDC
If you can't see the alignment pointer, it's directly below the center part of the belt connecting the power steering pump pulley to the water pump pulley (highest belt in the engine bay)
Old Dec 25, 2004 | 08:42 PM
rivneo1's Avatar
Question
Whats the correct degrees for an advancing timing on the KA24DE?
Im not sure if I did it right. I think mine is at 10 degrees or so.
Old Dec 25, 2004 | 10:34 PM
It's in my post:
"This needle is supposed to point to 20 degrees advanced. "
That's FSM spec for the KA24DE.
Old Dec 26, 2004 | 09:12 AM
rivneo1's Avatar
Question Just to make sure!
It's in my post:
Ok ,one more ?? ,is 20 degrees the normal timing or that would be if its advanced?
Old Dec 26, 2004 | 01:46 PM
NismoKa's Avatar
He said FSM SPEC....what does that mean? Hmm perhaps factory specs?
It says so under the hood too. Well on my s13 anyways.
Old Dec 26, 2004 | 02:01 PM
rivneo1's Avatar
Well I want to advanced mine ,so I dont know where Im supposed to exactly set it at!
Old Dec 26, 2004 | 02:24 PM
Well then turn the distributor more so the needle goes paset 20 degrees. Exactly where? Can't tell you, since there are no marks after 20 degrees.
BTW if you advance it, don't expect too much of a power gain, and I assume you are ready to use premium gasoline now, right?
Old Dec 26, 2004 | 09:08 PM
rivneo1's Avatar
I always do use 93 premium fuel especially Chevron or Shell ,sometimes when Im really I have to stop on the nearest gas but I do still use 93 ,thanX for the advice though.
Old Dec 28, 2004 | 05:51 AM
damn, you still have 93 out there? We used to have 92 as the highest common, but then they got sneaky and dropped it to 91
Old Dec 28, 2004 | 06:14 AM
Damn, Cali only has up to 91.. thats pretty crazy, I'm so used to seeing 93
Old Dec 28, 2004 | 06:56 AM
rivneo1's Avatar
Yeap a few days ago Chevron 93 octane gas was around 1.80$ the gallon or so ,lowest I had seen it is around 1.75
Old Dec 28, 2004 | 01:52 PM
yeah our 91 rings in at around $2.30/gal.
Welcome to California.
Old Dec 28, 2004 | 03:03 PM
rivneo1's Avatar
OMG ,I didnt know how bad its outhere but damn u guys got alot more hot chick on that side of the Country so look at it as a good thing to live there
I hope it get better for you guys outhere .
