Air intake problems
Old Jan 11, 2006 | 05:04 PM
gubermyster's Avatar
Unhappy Air intake problems
Well me and my friend installed a custom cold air intake that runs by by the battry and down to the front wheel well by the tire, well the car runs fine accelerating and idling at a standstill sometimes, but coasting in nuetral, and slowing down to turn and such the car drops to like 500 or less RPMs, and the car died one time but only that once, we did this on monday and i been driving it as is since. We ran a small ram intake type thing inside it for the tube that goes to the ECCS. I am not sure if my MAF sensor is just ****ed up, but the wiring looked fine when i checked it, was also wondering how to raise the idle on the car
thanks
Old Jan 11, 2006 | 05:22 PM
aallbbeerrttttt's Avatar
did you reset the ecu after you put it on? i put a CAI on my old civic and it would stutter and stall, but once i took off the negative terminal for bout 5 mins, everything was great
Old Jan 11, 2006 | 07:30 PM
yea its still idles really low, you think raising the idle would work?
Old Jan 12, 2006 | 10:39 AM
EDIT: Hey instead of double-posting, I'll learn how to use the button instead.
Old Jan 17, 2006 | 11:23 AM
did he also relocate the MAFS? Or just stuck a tube to the TB and put a filter on the tube as is?
Old Jan 17, 2006 | 11:50 PM
well i uninstalled it for the time being but yea the MAFS was right next to the battery maybe it wasnt vaccuuming enough air or something because when i put it back to stock it runs fine
Old Jan 18, 2006 | 01:13 PM
*Tx_BLooD_240*'s Avatar
hmm when i installed mine i didnt have to reset anything, wierd
Old Jan 18, 2006 | 04:00 PM
BigVinnie's Avatar
Your problem could be your IACV. Dumping some carb cleaner down the IACV should correct your problem. IACV stands for Idle Air Control Valve, I am assuming that your RPM's can jump, and fluctuate funny sometimes, so I thought I would kick down the info....
Old Jan 18, 2006 | 04:24 PM
The location of the MAFS isn't what I was referring to, but the connections for the MAFS harness.
seanchris16
Jul 20, 2007 12:25 PM
240sx'in
Sep 5, 2006 12:07 PM
Amolao
Jun 13, 2003 05:23 PM
igorsgonemad
Feb 25, 2003 01:37 PM
sr20240
Sep 11, 2002 12:53 PM
