antifreeze leaking into oil??? HELP please!!
Old May 2, 2007 | 07:47 PM
killerk240sx's Avatar
hey all i got a huge issue with my 1989 240sx it was sucking anti freeze into motor and burning so as every mechanic would do i pulled the head off replace the head gasket cleaned it all up put it back together took it for a drive and BAM its still sucking into the oil. it is sucking the hole rad of fluid in about a half hour and going into my oil but its not burning it??? im hopeing someone can help me out.
thank all kyle
Old May 2, 2007 | 10:56 PM
the head and or engine block could be warped, did you look into that or just replaced the head gasket?
Old May 2, 2007 | 11:04 PM
hi ya i had the head looked at measured and dunked its all in the area of good. plus if it was the head would i not be burning anti freeze? im not burning any its just going in and filling my oil. and the block seems fine i didnt send it anywhere tv i looked it over very well
Old May 2, 2007 | 11:10 PM
at this point the only other possibility that come to mind is that the head gasket in either the wrong one or that it was installed wrong.
i could be wrong on both counts but it's the only thing that come to mind this late a night.
Old May 2, 2007 | 11:17 PM
some people were saying it may be the seal down by the bottom of timing chain for fluid pump. i no people make mistakes and im not trying to sound cocky but the chance of it being instaled wrong are very sjim this was done to the cool and i took my time. have you heard anything about it coming around water stop or anything?
Old May 3, 2007 | 08:35 PM
I GOT IT THANKS. hi all i took off my timing cover and found out that the silicone gasket that is used to stop the antifreeze from goign throught the galeries right into the crankcase and it was melted and blown off. i asume that the owner of the car before me did not use high heat silicon so it melted when my head gasket went. well nice to no for the future thanks everyone
robalicious96
Dec 9, 2005 08:05 PM
SirHarley
Dec 6, 2005 01:08 PM
jpos985
Jun 6, 2005 12:33 AM
twoTinYaMoeBa
Sep 10, 2004 06:37 AM
tristan
Oct 29, 2003 12:43 AM
