Blown Timing Chain?
Blown Timing Chain?
I recently followed up on a newspaper add on a 240 that "needed work." The guy selling it said that it had a blown timing chain. If this is in fact the case, is this dificult to fix? When the timing chain breaks, does anything else break with it?
If the chain is broken, then there's a good chance the timing is outta whack and the valves and pistons have become well aquainted with eachother. (i.e. the vavles are toast) That is, among other problems you could encounter.....
