Bogging issue
Old Nov 12, 2007 | 01:30 PM
DALAZ_68's Avatar
Bogging issue
heres my issue
Chassis: 1990 240sx
Engine: 1996 engine
problem: bogging out at 3k rpm under load (when in gear), not reving up smoothly
now be4 i get jumped at here is wut ive done so far to avoid asking this
Compression test: 190 190 190 178
airleak test: tight as a virgin
EGR: blocked off completely by ebay steel plate
TPS: good (borrowed from friends car) working TPS set at .5 at idle
Injectors: working properly, even used stethescope to hear em
Spark plugs: NGK V power ( ithink) were brand new now have blow by and whitish tip, which means running lean i believe
thermostat: new
plug wires: new NGK
Timing: Stock 20BTDC setting
fuel system: new filter,strainer, and pump FPR reads 40psi at idle
MAF: proper voltage and works great, borrowed from same car as TPS
Grounds: all properly bolted down
exaust: no black smoke or any kind that would indicate blown H gasket or coolant leak
Temp sensor: did FSM way of checking if it works ( dipping in boiling water with thermostat) and is functioning...
ECU: was only throwing EGR nothing else
any body deduct anythign from this...ive gone to other forums and searched here aswell... worst case scenario id have to guess Knock sensor...whihc means ripping off intake mani...which i dont wanna have to do... anyother possibilities im more than willing to listen...
Old Nov 12, 2007 | 04:18 PM
dkdeleon's Avatar
check for vacuum leaks.
Old Nov 14, 2007 | 02:57 PM
DALAZ_68's Avatar
its been air leaked 4 times after egr assmbly was removed...
hennce my original post:tight as a virgin...no leaks man
Old Nov 14, 2007 | 03:56 PM
I'm gonna have to go with you on the knock sensor theory. Just solder a resistor in there.
Old Nov 14, 2007 | 09:44 PM
Enlefo's Avatar
Check your fuses.
Old Nov 15, 2007 | 10:50 AM
Check your fuses? WTF? The anti bog control fuse?
Old Nov 17, 2007 | 06:20 AM
dkdeleon's Avatar
Lol.
Old Nov 17, 2007 | 09:37 AM
cronux's Avatar
haha ry tellin it how it is. yea, imma have to say wire a resistor in the knock sensor
Old Nov 17, 2007 | 04:04 PM
Sevarg710X's Avatar
What resistor would you wire in for the knock sensor ?
Old Nov 19, 2007 | 03:30 PM
Talde's Avatar
i took all the air lines that go to the intake manifold except for the brake booster and fuel pressure regulator. my car also bogs at around that rpm. all i do is let it warm up and its good. hope that helps.
Old Nov 20, 2007 | 04:58 PM
Sevarg710X's Avatar
Still wonderin what resistor you would wire in cause that knock sensor is a pain in my ***
Old Nov 20, 2007 | 06:07 PM
I can't remember offhand, but i know that if you do a google search something will come up.
Old Dec 5, 2007 | 03:53 PM
osal1989's Avatar
so did u fix your problem??...cuz i have the same
onelove240
Mar 22, 2008 07:50 PM
redpotatoes
Dec 22, 2005 09:00 AM
colombia
Oct 17, 2005 06:45 PM
bottombunk
Feb 19, 2005 06:34 AM
Strizzy
Aug 26, 2003 01:15 PM
