broken fuel injector clips and distributor install questions
Hi, recently I've been getting some CEL codes that tell me my injectors are clogged and my cam angle sensor is faulty. I found some rail with injectors but I notice one of the injector have all for clips on the nozzle has broken off. Will this be a problem if I install them still? I also found a new distributor from a 95 ka and was wondering if it would fit a 92 ka. thank in advance.
the tabs on the injector help place them within the seal that goes inside of the intake... with the tabs missing there is a good chance that they can leak... as far as the distributor goes the plug might be different depending on the obd version of the car it came from... i would try to find a distributor for the correct year of your motor... less chance of there being a problem...
jackyliem
Oct 29, 2006 05:24 PM
