Cam Compatability
Old Oct 20, 2005 | 12:21 AM
JDMxDrift's Avatar
Cam Compatability
I have a KA24E, does the cam out of the 91 Stanza have the same specs? it has a KA24E as well.
Old Oct 21, 2005 | 09:07 PM
BigVinnie's Avatar
The degress to the cam has to be reset to fit the KAE for the 240's. Something with the production of the engines, not shure. But I wouldn't waste time installing a Stanza cam, the specs aren't that much different.
If you are staying KAE Devious KA sells a much more aggressive cam for the KAE. Price is $185, 270 duration, .433 lift INT / 272 duration, .448 lift EXH. The cam is worth it, I used a cam for my 8 valve NAPS-Z that was very comparitive to that cam spec, it gave my engine 15 more HP to the wheels, it will probably give the KAE the same results. Especially since the engine dynamic is the same, accept the KAE has 4 more valves to the INT, maybe a little more power than my 8 valve.
http://hybridka.com/sohccustom.htm
Old Oct 22, 2005 | 12:27 AM
JDMxDrift's Avatar
Well, i asked because i was going to buy a Stanza Cam to send to HybridKA to get re-ground, that way can still drive my car while the cam is getting ground. Can i still use the Stanza Cam?
Old Oct 22, 2005 | 07:37 AM
BigVinnie's Avatar
It would be wayyyyy to much work to install the cam, I don't even have an adendum to follow to install the cam. Without an adendum it's like trying to install a cam blindly....... Plus I think there was one minor change made to the cams for FWD, but I can't remember off the top of my head what it was???
Auto zone shows a cam install for the KA and the NAPSZ, but there is some conflicting information.
http://www1.autozone.com/servlet/UiB...3d8017f237.jsp
Why don't you make it easy on yourself and get one from a KA24e truck (frontier from 90-97) all the cams fit and are a direct install. There cheap at wrecking yards too.
Old Oct 22, 2005 | 12:23 PM
JDMxDrift's Avatar
I'm not doing the work. My local performance shop is going to rebuild the motor. So i can't use the cam? Thanks
Old Oct 22, 2005 | 09:37 PM
BigVinnie's Avatar
I would contact DeviousKA before shipping off the cam he has worked on both the FF and FR ka24e's. He could answer that question alot easier than I can.......
stealthhardbody
Mar 8, 2007 08:13 PM
jcl666
Jun 8, 2005 11:19 PM
JDMxDrift
Apr 14, 2005 12:11 PM
Fyre240Sx
Nov 1, 2004 05:54 PM
specialk22
Dec 12, 2003 10:09 AM
