Check Engine Light
Old Feb 25, 2004 | 05:41 PM
OWU Joe's Avatar
Check Engine Light
I just installed my RS Akimoto Intake on my 96 240. There is a plug that connects to the airbox, before the MAF. I wasnt able to connect this plug to any part of the intake so I taped it up and secured it. Now my check engine light comes on whenever the car is running. Is this going to be a problem for my car? Has anyone else encountered this problem? If I put my stock airbox back on will the check engine light go off, or will it stay on? If so, how do I reset it?
thanks guys
Joe
Old Feb 26, 2004 | 07:02 PM
dkdeleon's Avatar
you can reset your check light by didconecting the negative battery cable for a min. then reconnect it
Old Feb 26, 2004 | 08:10 PM
OWU Joe's Avatar
I tried doing that after I installed a 3.3k OHM resistor on the ITS, and it didnt work. So I simply used my OBDII handheld diagnostic computer, checked to make sure the ITS was my only problem, then cleared the code. Everything works great now, and most importantly no CEL~!!!
Old Feb 26, 2004 | 08:39 PM
95_240SXSE's Avatar
You could have just put some electrical tape over the CEL.
That would have been much more effortless.
Old Feb 29, 2004 | 10:04 PM
OWU Joe's Avatar
thats what I ended up doing. I put in the 3.3k Ohm resistor, elec taped it up. and used my OBDII tool to "erase" the error code. Everything works good now...if I could only keep my right foot OFF the floor.
nisar
May 24, 2004 11:43 PM
drew935
West Coast/Hawaii
Mar 28, 2004 11:36 PM
neolikquidx
Oct 16, 2003 10:08 PM
neolikquidx
Oct 15, 2003 12:18 AM
neolikquidx
Jun 16, 2003 08:44 PM
