Check Engine light
Old May 24, 2004 | 07:32 AM
nisar's Avatar
Check Engine light
Hello All,
Anyone know how to reset the check engine light ???
thanks
Old May 24, 2004 | 11:21 AM
nisar's Avatar
Can anyone help .....
Please !
Old May 24, 2004 | 01:04 PM
crimsontide240's Avatar
reset your ecu.....
Old May 24, 2004 | 02:50 PM
ixcocoyxi's Avatar
or you could try leavin the negative off your battery over night
that'll sure reset your ecu..
if its still on.. alot of something else could be causing it..
Old May 24, 2004 | 11:43 PM
Hollowpoint's Avatar
Damn lets see if i can explain it. Start by taking out your ecu hopefully u know were its at, if you dont its on the passenger side. Take it out, then on the back there is a circle with a place u can fit a flat screwdriver. Once u find that turn your key on not the car just the key. turn the circle all the way to the right slowly meaning clockwise until it stops then turn your key off and move the circle back until it stops again do it slowly. Then just put everything back toghther and it should be reset.
Hollow
drew935
West Coast/Hawaii
Mar 28, 2004 11:36 PM
OWU Joe
Feb 29, 2004 10:04 PM
neolikquidx
Oct 16, 2003 10:08 PM
neolikquidx
Oct 15, 2003 12:18 AM
neolikquidx
Jun 16, 2003 08:44 PM
