Clutch Pedal
Old Oct 14, 2006 | 01:09 PM
loc_staa05's Avatar
Clutch Pedal
Okay, i just finished changing the timing guide. I got everything back together this morning and all the fluids refilled. I go to start the car and the clutch pedal first goes to the floor slowly. The car starts but sputters and stalls. I go to start it again and the pedal wont even move. Could this be the master cylinder?
Old Oct 14, 2006 | 09:44 PM
was clutch fluid removed? if so the system needs to be blead...if not then it is possibly slave cylinder or master cylinder..
Old Oct 15, 2006 | 01:07 PM
loc_staa05's Avatar
no the clutch wasnt even touched. thats why i think its the master cylinder.
Old Oct 15, 2006 | 02:35 PM
LA_phantom_240's Avatar
Try looking under the car for clutch fluid leaking. That would mean it is the slave cylinder (very commom) or look under your dash at the clutch pedal and try to spot any residue indicating fluid leaks (less common) and also look at the color of your clutch fluid. Mine was chocolate milk-looking after my slave cylinder went out.
Old Oct 15, 2006 | 04:24 PM
HKST04Z's Avatar
heh the same thing was happeneing to me right after i got done changin my clutch......to fix that problem, right behind your clutch pedal is a Clutch Adjusment bar. its a little gold bar thats threaded on the end with a nut restricting the accutal pedal, adjust it to where its working fine
chitodsr
Jan 5, 2008 12:34 PM
x3240racer
Mar 12, 2007 04:17 PM
mr_lee21
Mar 27, 2005 02:03 AM
MykeCo
Oct 8, 2003 11:25 AM
Matt_240
Nov 4, 2002 06:22 PM
