clutch problem
Old Aug 13, 2006 | 06:55 PM
shigitySxSe's Avatar
clutch problem
ive searcehd a little and just need some more advice...
I have a 92 ka24de 5 speed and im having trouble shifting. When my cars off i can shift through the gears, but putting it into reverse(to back out my driveway) makes it grind just a little) then as im in the middle of the road and go to put it in first, the car just wont let me. Its so hard to shift, so i have to just turn the car off and restart it in gear to get it back in my driveway. I adjusted the clutch and my car went back to shifting perfectly, but only for a few days. Now its right back to how bad it was before and i cant adjust it anymore. I checked fluids and im going to check the slave tomorrow to see if that is an issue. Any advice, or is it time to just buy a new clutch? Any help is greatly appreciated.
Old Aug 13, 2006 | 07:11 PM
it wont let you go into first when your at a dead stop?
Old Aug 14, 2006 | 05:35 AM
right. I can be stopped, push the clutch in and it just wont let me go into gear no matter how hard i try. when the cars off though its fine? Anyway im checking my master and slave cylinder today and will go from there. I just wanted to know if anyones had similar probs like this before.
Old Oct 1, 2006 | 03:02 PM
Just thought I would ressurect this old thread because my car is doing the exact same thing. Just wondering if anybody has any ideas or if shigity figured out what the problem is.
Old Oct 1, 2006 | 03:39 PM
re037's Avatar
slave tends to fail before the master. easy fix. make sure you have someone to help bleed
Old Oct 12, 2006 | 01:53 AM
greenbastard's Avatar
sounds like your pressure plate is gone in the clutch....
Old Oct 12, 2006 | 09:59 AM
Zenki_SliderS14's Avatar
yeah im goin with pressure plate too. I had the same problem also..but resolved it by just getting a whole new clutch
vortxxe
Apr 29, 2006 05:22 AM
uvamosk
Aug 12, 2005 07:31 PM
Kaion1000
Aug 8, 2004 07:50 AM
DJ_Sunrise
May 7, 2004 02:44 PM
khiz
Mar 11, 2003 01:04 PM
