Do these make a difference ?
Old Sep 3, 2007 | 03:09 PM
S14_Turbo's Avatar
Getting 9 or 10 mm spark plgu wires cauz im changing my plugs.. does this even make a diff or matter at all ?
Old Sep 3, 2007 | 03:17 PM
i read somewhere that for a daily driver not only will you not notice any gains, but could cause problems. i don't remember specifics but i read it on the internet so it must be true.
if they are for your dd just get ngk wires and plugs.
http://www.ngk.com/default.asp
Old Sep 17, 2007 | 10:16 AM
92nissan's Avatar
THe size of the plug wire makes no difference at all. Most of the time if it's some crap brand like APC, they're just measuring the outside silicone size. The inside core is still the same as O.E. style wires. Accel and MSD have come up with some new race wires that are 5.5 mm. What you really need to pay attention to is ohms and resistance.
Old Sep 17, 2007 | 10:49 AM
The only wires that I have heard make a significant difference are Nology wires, which are rediculously expensive for a stock replacement. Just go with stock replacements, it's not like you're running an aftermarket ignition.
www.sparkplugs.com
By the way, what is with the epidemic of terrible spelling?
Old Sep 17, 2007 | 11:45 AM
92nissan's Avatar
www.sparkplugs.com
You are correct. Nology does make good products. I'd use standard O.E. wires unless you are going with a complete aftermarket ignition like ryguy said. Always remember that 1 upgraded part generally won't make much difference, but several upgraded parts (i.e. coil, wires, msd box, etc.) together will make a difference.
Old Sep 17, 2007 | 12:28 PM
I have the NGK ones. They are blue. They look neet
Old Sep 18, 2007 | 07:30 AM
CharlesJ's Avatar
Club240 Staff
Nology wires do not make a difference. Have had them on two cars and not only did I not see a gain (dynoed), but on my mr2, they actually cause a problem and had to be removed.
Spark plug wires can only hurt, not gain. Meaning a crappy set could cause problems, so just get a quality brand or OEM. I have always gone with the standard NGK
Old Sep 18, 2007 | 07:45 AM
yup i just ordered some new ones from nissan 70 bucks
Old Sep 18, 2007 | 08:25 AM
so the internet didn't lie to me.
Old Sep 18, 2007 | 09:24 AM
melchior's Avatar
... but on my mr2, they actually cause a problem and had to be removed....
I had the same issue with my Celica alltrac. I was told the Toyota OEM wires are higher quality than anything else on the market, even the 600 hp guys run them.
Old Sep 18, 2007 | 10:29 AM
Ugh I'm wrong again. I'm just going to stop posting now
bucket240
Nov 28, 2007 08:32 PM
jackyliem
Dec 19, 2005 03:07 PM
Monkey Boy
23
Oct 10, 2003 04:39 PM
95_240SXSE
Aug 28, 2003 08:50 AM
Jonas
Oct 28, 2002 11:20 PM
